2018 M8000 DSI MAX BOOST PRESSURE
Solid Turbos
44
58
55
UTAH
l am designing a turbo for a 2018 Mountain Cat DSI and I am looking for some data on max boost pressure short of internal parts becoming external parts.
madmax
3,146
Salt lake city
Is this for personal use or are looking to make a kit you can sell to the public? IMO, 90% of consumers aren’t ever going to run anything more than a pump gas set up. Assuming a splash of 110 is needed with most pump gas kits running 5-7ish lbs. On full race gas I’ve seen guys run up to 12-14lbs. With the right turbo, inter cooler, fuel, etc you could run more, but why. Although that much boost is a riot in open bowels and chutes, it’s not real
practical to ride as a dailey ride. It’s just not needed in the type tree/boondocking most guys do these days.
kanedog
3,112
3,870
What's it like riding in the bowels? Sounds like fun!
Solid Turbos
44
58
55
UTAH
I am thinking 7 lbs with the capability of 10 lbs. I want to keep the max boost level south of when things start coming apart. Just trying to determine a safe max boost level. Thanks for the input.
Wheel House Motorsports
29,933
5,968
SW MT
You can run 7-10# with ease assuming a good state of tune. good intercooling/turbo selection to keep charge temps down will ensure a lot more longevity out of things like reeds.
madmax
3,146
Salt lake city
Never answered if this was for yourself or for customers
RACINSTATION
7,503
3,459
Idaho
It all depends on fuel. I have been running the DSI between 5 and 12 pounds of boost for a couple seasons. They rip at 7 or 8 pounds and that is sufficient for most. I recommend 50/50 or 100 LL at 5-9 and at 10 or more run 75/25.
If you keep the octane sufficient for your boost your motor will last.
