F
I know everyone is sick of reading and responding to all these clutch threads but im looling for help and making sure im not missing something simple.
I have a 2013 LE 162". I broke the belt in with about 60 miles of easy riding with no WOT. The sled is all stock and the way it came from the dealer with no mods other than the MBRP can and Mod Rod vents. After 150 miles the belt was riding low on the secondary. I used the creep method to add a shim to where the secondary and track would just barely move when the back of the sled was elevated. While riding in the trees with the snow over the bumper and hood I stopped to check the clutch temps. The primary shive was at 200f at the crank center line and 180f on the farthest outside part. The secondary was at 165f and the belt at 185f. I found the belt to have a 6" portion of the belt where the cords where pulled.
I have a alignment bar coming to check the clutches for alignment but what else should I be looking for? My primary seems to be making alot of noise when its not engaged or just above engagment and at light throttle!
I wont be riding this thing if it turns out to be another belt burner....which is sad because its a awesome sled other wise!!! Thanks for any help!!!
