R
i have a 94 zr700 and hit a rock on left side and it bent arms, shock, ect. ect. . frame is still straight, friend has 96 zrt 600. will front suspension swap over.. thank you.. Robert.
changed both side a-arms and spindle, it fit well, had to use spacers on the bottom of the shocks, the 96 zrt has different spindles, still same ride hight, 1 inch wider ski center to center, didnt even have to move the tie rod ends to make it stright, just to let every one know if you need to replace front suspension. i got lucky and bought 4 arms and 2 spindles for $50.00. hope this helps someone else.
