156 m10 vs. 162/174 m10
roughrider99
1,805
252
83
34
Fernie,BC
since camoplast is coming out with a 156 3 incher, seems like a good combo of maneuverability with traction galore. On a boosted yammie do you guys think a 156x3 with a good m10 skid will pull chutes or will it still wheelie no matter what skid due to shorter track and high hp? i think that with 300+hp a 156 is gonna wheelie, but then again i do not have any experience with cr10 or m10 skids
byeatts
3,403
1,215
I feel the 156X3 will be a Boondocking dream:usa2:
D
Duke
2,159
782
I think a 156x3" with an M10 style coupling skid would work alot better than with out. Would probably climb better than a 162x3" without an M10. One of the guys we ride with runs a 155 Baker skid in his turbo pro, it does very well climbing.
Iceman56
1,249
466
83
I think a 156x3" with an M10 style coupling skid would work alot better than with out. Would probably climb better than a 162x3" without an M10. Trevor Tancock runs a 155 Baker skid in his turbo pro, it does very well climbing.
Duke what's your opinion on a 162x3" compared to a 174x3" both with an M10? Is 350hp too much for a 162 with M10 to keep the front down?? If it's not a huge fresh powder day will a 162 keep up with a 174?
D
Duke
2,159
782
IMO, no comparison to a 174x3". A 162x3" is no small track either, very capable track..
motojunkie101
MODERATOR: Premium Member
805
Sandpoint, Idaho
This is apples to oranges, but I do remember reading about Amber Holt trying to go to a 156" track on her boosted cat. They couldn't make the timbersled work for her, it would wheelie out no matter what they tried. I think they ended up with a kmod to keep the front end down.
The info on her skid swap is in post 103:
http://www.snowestonline.com/forum/showthread.php?t=170731&page=3
Anyhow...I think the point is, yes its probably doable with an M10 if that is the direction you want to go.
P
pylon
473
88
in the triple slide
next year ill be running a 156 3 inch with a k mod skid and a skinz front end bolted to a built impulse nytro . Hope its as fun as i think its gonna be :face-icon-small-hap friend of mine has a 144 mcx nytro and its a blast ! just needs a decent skid . hope the k mod works out . still looking at a baker m10 though . good thing i have all summer to think about it
B
BigFish BC
3,348
1,139
kitimat b.c
the next skid will be bakers or cr10, I'm just up in the air on what 3 incher to run
go with the baker they work the same & you can save some money,it actually more adjustable if you get the mag blocks & quick ajust limit staps.the 3 inch is a easy decision if you ride allot of deep snow go 3 if not 2.5 its crazy how much more traction you get with the 3 inch.
byeatts
3,403
1,215
i run two shims on the 156 Timbersled to make it couple much quicker, Seems to correct the wheelie problems
roughrider99
1,805
252
83
34
Fernie,BC
I got a good timbersled with the exits I shimmed it but not friendly to adjust quickly for different conditions, plus I don't think it will work well with big boost
B
BigFish BC
3,348
1,139
kitimat b.c
put it in a chute like monster with 3ft of pow & 15+lbs of boost & they just arnt in the same league that way they do work but only to a point.
roughrider99
1,805
252
83
34
Fernie,BC
The question is with 3ft pow, big boost for all the track speed you can get, will an m10 skid and a 156 3 incher make it feasible to pull the monster?
roughrider99
1,805
252
83
34
Fernie,BC
Oh ya it is the best on the snow but I figure 25lbs of boost might still wheelie over due to shorter leverage compared 162/174
P
pylon
473
88
in the triple slide
any idea what the baker is gonna cost you ? the Kmod just seems to be a good option for 2500 bucks ready to bolt in .With a baker you need a stock 153 skid and youre still stuck with all the stock parts other then the arm and shock .
roughrider99
1,805
252
83
34
Fernie,BC
I have a 2 stock skids at home, but I'm pretty sure baker will build nearly complete suspension minus rails which iceage can do
B
BigFish BC
3,348
1,139
kitimat b.c
yes they do, but a complete one gets pricey too, but i like them better than the m-10 lighter & more ajustible.it will work in 3ft of pow with a 156 but will take more skill,watched scooter do it with a 2.5 155 on his pro but he had to work it.:face-icon-small-hap
