I just sent all of my shocks to Nextech in Sherwood Park for revalve and Evol chambers. I hear it is worth it.
Sent from my SM-G930W8 using Tapatalk
Did that shock bolt right in or did you have to change some stuff? I just picked up an Evol R for my 14 & there doesn't appear to be enough clearance.I added the Fox evol on the rear track shock with the revalve. Helped a lot with handling in all areas of riding. I have a pro 600(wife's) also. I don't ride it much. Just a quick help up a hill or out of a hole or zip around at lunch. I prefer my Proclimb over that. But that's an argument elsewhere x 100.
Now I have added the 2017 Mountain Cat chain case and a TKI belt drive and a 3" Powerclaw. I bet my sled will be even more tippy until I can get the time to get it figured out.
Do you guys have a suggestion for the pressures on my front Fox 3 air shocks?
Also, if this doesn't work out, I am considering a Z Bros 38" front A arms but, I have had my front Fox 3 shocks modified (rods cut) to accommodate the 36" Cat front end. I don't think that will work?
I still have the 2015 rear skid with shortened up rail caps. I'm also wondering if maybe I should be adjusting how many threads I have showing below the lock ring on my front track shock?
