T
just got to west yellowstone today, went out for a quick run to test out my new to me 07 m1000. I trail ride about 5 miles, no problem. Hit a hill, full throttle up it, I hear a little grinding, I think it is ratcheting or hitting the ground under the snow. I ride a bit more, then all of this sudden on a climb I just stop. I think I blew a belt, check it out, nope belts fine. I put the the sled in reverse, it goes back into gear, and I am fine for another 30 seconds till I climb again and sled does the same thing. It is going into a "neutral". I trail rode the sled back with it going into nuetral every minute or so. I put it into reverse to get the gears or whatever to realign again, and it works for a minute.
I have the DD ripped apart right now, everything looks good, except there is slight wear on the edges of the revers forks. I am thinking of putting it all together and disconnected the reverse servo motor, see if that makes a difference. Any ideas before I put it all back together, and see this.
Thanks. I will be waiting for replies
