Hello guys
I have a 2011 M8 sled with Push HP Turbo kit with 2 injectors and no cooler running at 1500-4500ft
I cannot get the sled below 13.0 AF on WOT and 1260f at best EGT when I had turned the fuel pressure to 50 psi
I am running 114LL race gas so the numbers should be lower, The turbo is boosting 5 psi
When I got the kit the numbers on the EFI attitude was
was now
Green 1 1
Yellow 1 2
Red 8 8
green/blue 4.5 8
yellow/blue 4 3.5
Red/blue 4 3.5
Egt was 1300+ and AF nearly 14
I changed the numbers and cranked up the fuel pressure to 50psi( goes up to 55 at boost) but I only get the AF to 13 and the sled is obviously not good at low rpm
Something is just not right, I should see much lower numbers on race gas at 5psi boost
What could be my problem ? injectors maybe or something else ?
Thanks in advance
was now
Green 1 1
Yellow 1 2
Red 8 8
green/blue 4.5 8
yellow/blue 4 3.5
Red/blue 4 3.5
Thanks in advance
