I had a piston seize today in a m1000 BD RG 10.5lbs . The sled had run on two other trips with no issues, coolant temperature was good and EGT temperature looked good. The sled was warmed up properly and we had ridden 4-5 miles.
The piston was not melted or lean just seized mostly below the exhaust port and slightly on intake side. We checked oil system and it is pumping oil.
Has anyone else had this problem and what would be the cause?
