E
I finally got to build one with the ball joint idea. All the tubing is either 1/2 or 3/4 square tube with. 060 wall thickness. Mostly straight pieces except a slight bend under the motor. If it doesn't break I'll machine the fork tubes down to the od of the top clamp all the way down and run a top clamp on the bottom without needing a shim. The rfs motor is 58 pounds with reverse gear. The track is an inch in front of the swing arm bolt. Seat height is 35". There is no strut or track frame. This is it. I ran the back half this way on my raptor and saved 30 pounds but wasn't enough gain to off set the heavy engine. Track is 137 yeti on a 17 mh le.
