Personally, I use the Garmin Rino's. I like being being able to locate my friends that are also using them. When in a tight tree pack, it saves a bunch of searching time. I got a push-to-talk mic off of eBay and it works great.
Just looking for some insight on backcountry two ways. Preferably ones that pack into the backpack and the mic strapped seperate to the shoulder strap of the backpack.
Sent from my SM-G900V using Tapatalk
This has worked good:What mic did you get?
I have not had a problem hearing it. I keep the microphone as high up on the strap as possible.How do these work while riding.. If I was brapping through the trees and my buddy wanted to get a hold of me could I hear it.? Secondly. How many radios will work together.
Rinos are nice I have 2 myself, but try convincing most that they need a $500 plus gps/radio. It's not easy.
http://www.ebay.com/itm/Hand-held-S...US_Radio_Comm_Microphones&hash=item27c836a8fb
eBay is a great place to find used ones for a good price. I used to have a 530 HCX, but I switched to the 120 and did the Ski-Doo Montana dash-mount for my primary GPS.
sledheadd said:You may want to check these out
http://www.ruggedradios.com/index.ph...oducts_id=1274
They are both uhf/vhf they come with some gmrs channels pre programmed and you can also programme the others in your self. Dual band scan can monitor 2 channels at the same time(one uhf one vhf if need be) Has a longer range then most others that i have tried. Can be set to monitor road frequency when traveling haul roads. Also have a fm radio built in.
I have mine wired to speakers in my helmet with a mic and push to talk button strapped to my avy vest. One can also get a mic to strap to your shoulder if you prefer that.can be used on the repeaters.
I also got the longer antenna for even longer range transmissions
