Where/How to permanently mount battery tender leads on Gen4 electric start sled?
acgreen
128
30
Any info and pictures of mounting connections would be helpful. Want to see what others have done before I do it. Battery cover has 11 ltr. Rear seat bag mounted on battery cover. I Want the leads, from the battery, to be outside of the battery cover so I can attach leads from battery tender to them.
acgreen
128
30
I've ordered the tender wire to the battery and the unit that mounts to the battery cover. When they arrive, I'll post pictures of the installed unit.
acgreen
128
30
Saw picture of "Cole Hersee Battery Terminals" mounted on sides of battery cover.
Twistgrip
102
58
Take battery cover off, put the battery tender pigtail on the battery and then have the end come out by the back left seat and put the cover back on.
Did this on the kids gen4 summit. Worked great, when not in use I just tucked it under the seat.
acgreen
128
30
I like your idea. A lot easier to do then my idea of a plug attachment on back end of battery cover. Will check it out on my sled
acgreen
128
30
I attached battery tender wire as "Twistgrip"(above) suggested and a lot simpler to do. First picture is connection to battery. Second picture is tender wire coming out of the front of the battery cover. Third picture is tender wire connection end with all the tender wire tucked in space under rear of the seat. Simple and easy to do.
Twistgrip
102
58
Look's good, exactly what I did! Clean and easy.
snow-doo
448
306
Atascadero Ca
Didn't they come that way from the factory? I had two of them that looked just like that when i picked them up from the dealer.
