Weighed Pro Today 432 lbs
wfieldin
1,911
444
83
Denver
2013 800 155, with 858 RK-TEK. 432 lbs. Not Bad!
Weighed it with a full oil tank and full coolant level, we siphoned gas out of it.
Weight saving features:
Coated stock pipe,( heat shields removed)
Super Q can
ZBROS 36 A-Arms
Fox Floats front and rear
Weight adding features:
BD Box
Dan Adams NXT-LVL windshield bag
Polaris Extreme front bumper
Skinz Rear Bumper
Wrap
ICE STORM REVERSIBLE SCRATCHERs
Let it snow, I'm ready!
J
Jaynelson
5,542
Nelson BC
That's great! If you go in to the Yamaha section that have convinced themselves that the new Viper somehow weighs about the same as a Pro.
They must have better drugs over there....
AKFULLTHROTTLE
1,987
1,146
Alaska
Well the new Viper does not weight much more than my Pro. Once you start adding Mods and the Electric Start as well they are not that far off but the Pro still feels waaay lighter...
P
Jan 16, 2013
37
13
8
Bethel, Maine
I see you are running the Skinz can... did you test the sled with and without the can? I put a Skinz on my 858 and did some back to back testing. I lost 2-300rpm with the Skinz. But I am not running at elevation.
wfieldin
1,911
444
83
Denver
No I have not compared cans, my RPM's are where I want them with the rooster weights
diamonddave
Chilly’s Mentor
5,578
3,893
Wokeville, WA.
After swearing I would stick with the stock can, i tried a different can and had the same results. At 3,000-6,000 ft. One of the popular ones on a stock bore.
I will stay with stock.
wfieldin
1,911
444
83
Denver
More weight shaving
Diamond S Ti can, will drop 4lbs 3 oz
Stock front and rear bumper dropped 11 oz each
VForce3r reeds weigh 8 oz lighter than the stock assembly
Headlight delete cut 2lbs 12 oz, going to add the mtn-fit resistor though
May give the Skinz seat a try, guessing at least a couple lbs there.
May start looking at some ti hardware, sure wish it would snow it would save me some money!
R
rmscustom
2,181
1,801
I'm assuming you weighed all parts... Diamond S is advertising their quiet can as a 7.4lb savings...
wfieldin
1,911
444
83
Denver
I am waiting for the can, advertised weight is 2 1/2 lbs, not the new quiet can, the original one. The weight differential I listed is from my current skinz can. Yes I am weighing everything on a Park scale I use for my bike stuff.
R
rmscustom
2,181
1,801
I am waiting for the can, advertised weight is 2 1/2 lbs, not the new quit can, the original one. The weight differential I listed is from my current skinz can. Yes I am weighing everything on a Park scale I use for my bike stuff.
I see now... I thought you meant the Diamond S can was only a 4lb 3oz savings... My bad.
Btw I held it at haydays and believe its less than 3lbs.
