L
I'm venting my new sks and was wondering what kind people have used and seem to work well? I have looked at fire and ice products and they look very well built . Any info would be appreciated thanks
I wouldn't waste your money honestly...250 miles and the clutches are perfect and not nuclear hot so the changes they made work great!
Just my $.02
You obviously weren't around for the 900 dayspolaris has never had hot clutch problems it's one of the huge pluses for riding polaris . if you do vent it i have been very happy with 2cool's they even have a deal where they will recover you old beat up vents , top notch company.
What changes were made to help the clutches run cooler?
They geared it down from a 2.10 to a 2.23 plus they are running a straight angle helix.
Vents are truly a waste of money.
If the clutching is way off you will still build heat even with two blowholes.
If the clutching is stock (good) you need zero vents.
If you want them for the "look" then by all means go for it.
But be aware that all they're for is looks.
BINGO!! That has been my experience as well. The only time you need vents (other than the factory ones) is when you are in deep powder. And guess what . . . they are covered up with snow and not "venting" at all. Vents are almost worthless, in my opinion =)
When covered with snow the heat melts the snow that is sticking to the mesh / vent; which is allowing more heat out / away from your clutches than having a solid piece of plastic.
That is true if you are sitting still. When moving, which i prefer to do, the snow is continually plugging up the vents. The AXYS seems to be vented pretty well, without any aftermarket vents, and air does rise out the top vents when sitting still.
The only aftermarket vent that i can see would do any good in deep snow riding, is the "blowhole" as it is forced air ventilation, and does not rely on movement to create airflow. And no, i dont have one on my sled, and dont plan to get one.. . just an observation. My clutches just stay warm and easy to touch. I guess i have the clutching right =) Carls Cycles does amazing work!!
If your clutches stay warm and easy to touch after some hard riding...I would say fa'sure all dialed in!
Did you send your clutches into Carls; or are they local for you?
