T
I was wondering if anybody has figured out how to use DPM with the turbo setup on the rev. It would be nice to run like it use to stock. Any info would be helpful.
nope....everyone uses power jets....
I wouldn't say it is impossible to get the DPM system to work with a turbo.
People are right in saying the DPM needs a vacuum to lower the pressure in the bowl and in turn lower the amount of fuel allowed to pass through the jet.
If you add boost this line will become pressurized and push more fuel through the jet, but when the boost is being built you need more fuel. This is just the basics of it. It would take a lot of recalibrating and in my opinion you would have to add a little something, or do some reprogramming to make the system work properly. Anyway as Stalefish said there are people working on it, and I hope they get it working.
Cheers
DPM will not work with a turbo. It requires vacuum to operate and the turbo Pressurizes the intake.
Thats going to take one hell of a vac reserve canister to lower the pressure in the float bowls when you have 10psi+ of boost at XXXcfm pressurizing it!
we are working very hard on this problem and will soon have a fix. By the time we a done you can take away fuel or add fuel on the bars or tank.
last year on the stock 40mm carbs, i was seeing around the 1250egts on average, with mid range spikes to 1350f
this year with the 42mm carbs i was told to raise pilots needles and mains to compensate for lower air velocity from larger bore lessing fuel threw jetting and leaning motor egts
