Trimming Rails?
xring60
1,595
41
48
Mountains
So, if I install a anti-stab kit (such as SLP's) and replace the limiter strap cross shaft, can I trim the rail tips back quite aways and not re-install the black plastic tips?
If I can get away with out having to remove the suspension I'd be really stoked!
Thanks!
mountainhorse
18,606
11,814
West Coast
www.laketahoeconcours.com
Pulling the suspension is SUPER EASY.
Dont try to do this with the skid in the sled.
The ONLY reason to trim the rails is if you are running Combo drivers (Avid, Wahl).
Are you running combo style drivers?
What is your reason for trimming the rails back?
xring60
1,595
41
48
Mountains
Yup, I've got Avid 8 tooth 3.0 extro's. Done a lot of work to the sled lately to fit my new 174x3 didn't feel like dropping the susp to add the anti stab. Plus the Anti Stab kit looks like it can be installed easily with the skid in.. Can I leave the black caps off the front of the rails with out any issues
Snowjunky
410
52
Loveland,Colorado
I couldnt imagine putting a anti stab set of rollers in while strill in the chassis. I have done 3 of them. Pull it would be my recomendation for what is is worth. Also how the heck did you get the front bolts in without trimming the tips? I put the plastic tips back on the 3 I did.
xring60
1,595
41
48
Mountains
I've set the skid back 2" and down .75 Yes, I have trimmed the rails 1" already and with the skid fully extended the tips hit the extros, looks like I'll need another .500" just to clear! Okay, so it looks like I'll need to pull the skid arrrgggh! Has anybody trimmed the rails back to the cross shaft and left the black caps off? Maybe 45 degreed the bottom corner of the rail?????
I'll try to post some pics of the Dragon Slayer!!!
winter brew
4,332
LakeTapps, Wa.
I'm pretty sure you'll be pulling the skid when you put the new 174 in.....or am I missing something here? Takes 10 minutes to pull the skid. :beer;
xring60
1,595
41
48
Mountains
Yeah, I think you guys are right... The skid should come out to do it correctly, what's another ten minutes and a 6 pack of suds!
The track is already in along with the suspension when I noticed that the rails hit the drivers, cool huh?
xring60
1,595
41
48
Mountains
Actually the rail extension is only about 7.5" center to center. Same as going from 136 to 151 or 144 to 159. Been done many times. It looks as though most mfg's used .50 thick Aluminum and I used .625".. So I believe we should be golden.
skibreeze
10,463
3,477
Colorado Springs
Here's what I did for my edge
xring60
1,595
41
48
Mountains
skibreeze, looks good! Did you relocate your limiter strap cross bar? Or is that the original location?
RYDPWDR
542
172
Billings,MT
xring60
Did you get the new extended chain cast from AVID to run the 174x3 ? If so, I would like to hear how it installed and fit? Thanks
btw..I would remove the skid to trim, much easier. Here is a picture of my trimmed rails.
xring60
1,595
41
48
Mountains
Yeah, bought his extended chaincase.
Installing the chaincase isn't too bad. There is a fair amount of trimming and cutting that needs to be done but all in all its pretty basic... I'll try to get some pics up soon.
matt
5
48
Southern Maine
www.myspace.com
xring-
you can trim the rails to the crosshaft and still use the caps. just use the crosshaft bolts. you will need to trim the caps up, though. i would still use the anti stab kit though.
ryde-
where'd you get those rail caps?
xring60
1,595
41
48
Mountains
Thanks for all the great info guys! Here's a couple of pictures..The right footwell gets trimmed pretty agressively. (weight loss)
RYDPWDR
542
172
Billings,MT
xring-
ryde-
If you are talking to me, those are stock one's trimmed down with a grinder.
