G
Always learning, always playing so I have a question.
Does Poo give an altitude and pressure required to test the TPS and set it to their spec?
This is a mildly modified sled not stock.
I've read and been told how important the TPS setting (100th of a volt??) is and I've read about the "bog" too. Mine has a bog I can clutch away but I prefered not to.
I've been using the PCV to tune my sled and I could never quite get rid of the bog using memory and changes at home or the truck.
When I asked for a cure I was told to check TPS voltage or about throttle safety switch thing. All done a couple of times and no success.
So I bought a Boony box ('13 model) again and packed up the PCV. First thing I needed to do was sync the Boony box to the TPS position checking idle and wide open. My no.'s were different than suggested (oh boy here we go again lol) so I asked questions and didn't come to a conclusion really just went for a tuning ride.
The Boony box gives you a display and allows you to change things in the field (missed that). Because I had questionable TPS no.'s I checked these up at altitude.
I found those no.'s were different at 6000' than they were at 1100' and different again at 3500'???
Has anyone ever noticed this? Does Poo change fueling some using TPS voltage changes? If a shop at 5000' sets your TPS voltage will a shop at 100' find it wrong?
This is what my Boony box showed me this weekend.
Anyhow MY bog was a small window of too little fuel at light throttle positions right at 6000 and 6250 (+7% which was a surpise because the ethanol mode made it worse before). And, I was about to take a half a gram off the tip because of a slight backshift issue but a little more fuel at full load 7500 and a little less at 8000 fixed that too lol.
Thanx for making it easy again Boondocker.
