rule of thumb, preload is adjusting the force required to overcome the spring tension; engagement. final tension of a spring is the same no matter what force it takes to get it moving. The thunder products glide washers are probably not even 1/32". I would try one, especially if you have the exploding cover model. I dont like adding ANY rotating weight so would use the ZRP Ti cover bolts same time. I like the ease of ajustment on the CPC weights. They were also well matched on my gram scale unlike the factory weights. I would do these little tweaks to any new cat first thing, just me.
