Clearly, you'll need the Alaska seal of approval for your marketing.
Now, ordinarily, I get the big bucks for crash testing sleds and sled parts but I will waive my fee in this case.
Just send up a set (black please) and I'll put at least 1,200 miles on them and provide you with post-ride performance summaries throughout the season.
You're welcome.
So is this the same concept as the skinz concept front end for the nytro?
How much money?
You're welcome.
werry good looking
I hope they earned a lesson with the Nytro IFS and put 5/8" or larger heim joint in the bottom A-arm instead of the cheap 1/2" that they used on the Nytro.
How much
Cool stuff Paul.......nice sled.
I like those.
Would like to see some side by side pictures.
You're welcome.
To save on Shipping send a second set and I will put them through the fat boy test. My current arms are customized with these specific dents in them just for me. I also put 1200 to 1600 miles on per season and am happy to crash through trees & rocks for your needs.
Why do these aftermarket A-arm builders insist on using a hiem joint designed to be strong in tension in a place (lower A-arm) with high shear forces? It makes no sense. It is not lighter, just weak and cheaper to produce. Make a set with a spherical bearing pressed into the lower arm itself and I would by a set.
