I have to agree that my stock primary spring was binding really bad and this is one reason the SLP spring works so good for me. I tried and switched back to my stock titanium/yellow spring when having RPM issues(stuck EV servo), and had a real hard time to get it to sit in the primary cover completely as well as the spider cup. I did notice abnormal wear on the inside of the spring windings as well. Upon startup I realized it might take a bit for the spring to "seat" fully in both cups.
My sled revved up to 4500RPMs before engaging initially and really wasn't consistant either. Wasn't happy but tried it out anyhow. Noticed my primary heat was quite a bit hotter and engagement never fell below 3750 the whole days ride. Never cooked a belt, but the snow wasn't deep either. Really didn't like how high it engaged compared to the SLP so switched it back after the days ride.
Black/Yellow SLP primary spring is shorter but stiffer rate. Easier to install sits right in both cups with no binding at all and alot easier to get the bolts in the primary cover back on. Right off the get go I noticed RPMS steady engagement all the time around 3650RPM. Way less primary clutch heat, gets on top of the deep better and rode a day and a half in 3ft of pow burrying it over the headlights constantly on downhill carves and pulls so hard uphill I had to turn out and sidehill WOT for 30-45 sec long pulls back to back. Never blew a belt, clutches got warm to hot but never hot enough to burn the tips of your fingers on first touch. Even got stuck a few times after hanging up in creeks and trees with no clutching issues. Sure makes a difference going back and forth to that spring and I don't want nothing to do with the stock primary spring ever again. Should never have been on that sled, doesn't fit right or work for the application of the sled whatsoever. Basically I consider that spring a flatlander spring for drag racing the way it engages so suddenly and aggressively compared to the black/yellow SLP.
My backshifting isn't what I'd like, so I am looking to a torsional conversion on the secondary. Other than that my clutching is pretty darn good for the stock gearing, can only get cooler with the M8 gearing I figure and better engine braking with the torsional. I am running the 046 belt as well and sure flog the crap outta my sled everywhere from 800-8500ft in elevation. Either flapper closed or WOT, not much in between and always 1+ft of powder or I'm not riding.... As mentioned, this is a mountain sled, and that's all it gets used for, deep snow or hard climbs.... Good luck.
