Ski-Doo 2019 Product Updates
Ski-Doo Klim EZ Lynk
Dear Ski-Doo Riders,
Back in February 2018 we announced several product improvements with the goal of maximizing belt life on Model Year 2019 Ski-Doo snowmobiles. Those improvements include:
- Side panel intake ducting
- New belt guard
- Finned secondary pulley
- MAG-side engine mount
- PTO-side engine mount
Additionally, all 2019 Ski-Doo Summit and Freeride models have updated pulley calibration.
You may remember several updates were announced around this time last season with the goal of reducing CVT temperatures and improving belt life on select REV Gen4 Ski-Doo snowmobiles.
While those efforts were successful for the majority of Ski-Doo riders, we still fell short on our product promise to a few of our valued customers in specific riding conditions where too much engine movement caused a different type of belt issue.
To select Ski-Doo REV Gen4 owners who experienced premature drive belt failure, we have been hard at work on a solution. We hope you’ll give us the chance to make good on our promise with the following updates installed at your local Ski-Doo dealer:
The applicable solution depends on where you ride, and the unit’s altitude calibration.
Solution 1 - Sea Level calibration (below 1 200m (3,940 ft))
● Install engine mount update kit.
● Replace clutch ramps.
Solution 2 - High Altitude calibration (above 1 200m (3,940 ft))
● Replace clutch spring.
We know you may still have some questions, and we’ve tried to address many of them in the following Q&A section. If you have further questions, your Ski-Doo dealer is equipped to assist you.
Thank you for your loyalty and patience as we continually improve to deliver the best experience on snow.
SKI-DOO 2017 to 2019 PRODUCT UPDATES FAQ
1- What is the potential problem?
The drive belt is a wear item that needs replacement at regular intervals. However, some units under specific riding conditions, may experience premature drive belt failure.
Belt inspection may reveal the following, but are not limited to:
– Top portion peel off
– Top portion cracks
2- Which models are involved?
The 2017 and 2018 Summit and Freeride models not registered.
Some 2018 Summit and Freeride models registered.
3- What will BRP do?
The fix consists of new, stiffer engine mounts on both PTO and mag side, as well as new clutch calibration parts.
Solution 1 – Sea level calibration (below 1 200m (3,940 ft))
4- What should I do?
Contact your dealer to set up an appointment.
5- What does “select” mean when you say “To select Ski-Doo REV Gen4 owners who experienced premature drive belt failure, we have been hard at work on a solution.”?
The select units that are included in the warranty campaign have a documented premature belt failure. Either a warranty claim or WebCase has been logged to BRP in the last season.
6- I have experienced a premature belt failure last season, but I’m not included in the warranty campaign. How can I be covered for the upgrades?
Please contact your dealer so BRP and your dealership can evaluate it for potential consideration. Bring any supporting document, such as belt invoices, to support your request.
7- I’ve had multiple belt issues last winter. How can I get a definitive fix?
8- BRP had belt issues on 2017 models, supposedly fixed for 2018, but it wasn’t. How can you be sure that the new fix will work?
The initial problem with 2017 models was related to excessive heat in the engine and CVT compartment. This was addressed on 2018 models, but the failure that surfaced thereafter, in specific riding conditions and altitudes - and to a much lesser degree - was related to engine movement and clutch clamping force. The failures seen in the 2 years were not the same. Although BRP firmly believes the premature belt failure is addressed, the belt remains a mechanical fuse in the drivetrain system, extreme use can result in belt failure in such circumstances.
9- Will BRP cover my failed belts?
If it is possible to validate that you experienced premature belt failures last season related to excessive heat in the engine and CVT compartment (for Model Year 2017) or related to engine movement and clutch clamping force (for Model Year 2018) please contact your dealer so BRP and your dealership can evaluate it and come back with an answer.
10- I’ve experienced this issue on my Renegade. Why isn’t BRP doing anything for me?
BRP, on an exceptional basis, covered belt failures last year in order to accelerate our investigation process. It was determined that failures were due to engine movement, seen mainly in Mountain snowmobiles. Please be aware that belt failures may be caused by other issues also. We suggest that you visit your dealer for proper and complete diagnosis related to your specific situation. If the failures you’ve experience can be validated, BRP and your dealership will evaluate and consider assistance on the available solution (engine mounts).
11- My belt wear was OK, but still, I want to make sure my snowmobile has the latest upgrades to avoid any failure in the future. What should I do?
Contact your dealer to discuss the situation. Since belt failures were localized in very specific conditions (altitude, snow condition & riding styles), the proposed fix may not be required, or even desired, for your situation. Consider that the fix has some impact on engine vibration levels, being slightly higher at low RPM, and a slight change in throttle response, due to the new calibration.
12- My Model Year 2017 sled was supposedly repaired last winter, but I still had belt failures. How can I get the new fix?
Contact your dealership to set up an appointment.
13- How about consequential damage for the failure such as my CVT cover and the bent body parts from those blown belts?
If it’s determined the belt failure was abnormal, the belt itself as well as consequential damage may be covered by BRP. In the case of an extreme situation, your dealership will contact our technical experts at BRP on a case-by-case basis for guidance and evaluation assistance.
14- How do I know these blown belts haven’t affected my engine’s durability / longevity?
The Rotax 850 E-TEC is a proven, solid engine with significant engine protection measures built into the Engine Control Unit. We are confident that a belt failure will not cause engine damage.
15- Is there any plan if the fix provided doesn’t work to owner’s expectations?
16- I notice that this is only mentioned for Mountain sleds. Will trail riders be taken care of as well?
For the 2018 season, the vast majority of belt failures were experienced by Mountain units. Trail units experiencing belt failures can still get the engine mount upgrade. If the failures you’ve experience have been documented (invoice, Case), BRP is able to have a special consideration for assistance on the available solution.
17- Is this update going to be a recall or going to cost us 2017 owners more money on Top of what we already paid for the sleds and belts for this season?
The solution available is for 2017 / 2018 Mountain units that have a documented failure in the 2018 season. It will be covered under a warranty campaign, therefore at no cost to the customer.
18- How long does BRP consider a “normal” belt life should last?
Belt life is highly dependent on multiple factors: riding style (RPM, speed, and engine load profile), riding conditions (altitude, snow, temperature), clutch calibration, etc. Some riders have ridden 15,000 km (9,300 miles) this season on the same belt on their 850 whereas some riders change their belt every 1000 km. If you’ve experienced multiple unexpected failures at low mileage, and you have not changed your riding style, please contact your dealer for a proper diagnosis.
19- I’m thinking of buying a 2019, will the belt problem be fixed?
Below is a summary of the model year 2019 updates. There are some specific configurations, please refer to your dealer for the details of a given model.
2019 MXZ / Renegade / Backcountry (1.6” track)
● New Engine Mount (PTO side).
● Improved CVT ventilation with a finned QRS pulley (850 E-TEC only), belt guard and side panel with ducting
2019 Summit / Freeride / Backcountry (2” track)
● New Engine mounts (MAG and PTO side).
● All Summit and Freeride 850 E-TEC models receive new pulley calibrations (sea- level and high altitude).
20- Is the built-in clutch offset/wobble a contributing factor to this belt issue? It seems like that was a poor attempt to address this.
BRP has been using a Patent Pending technology on the pDrive clutch to reduce vibration felt by riders of Rotax 850 E-TEC powered sleds. This unique new solution adds no weight but solves the vibration issue many large displacement two-cylinder snowmobile engines experience.
To minimize vibration from the extra 50cc’s, extra 10 horsepower and 30% faster response of the Rotax 850 E-TEC, Ski-Doo engineers designed an industry first, counterbalancing pDrive fixed clutch sheave.
The built-in offset was very purposeful in reducing vibration and is not any kind of factor in premature belt wear.
21- I’m considering buying a new non-current Summit/Freeride - will my sled have the updates done to it?
Yes, all unregistered 2017 and 2018 Summit / Freeride units are included in the newly released warranty campaign to get the latest upgrades.
22- If I buy a used Summit/Freeride and experience belt failures, will I be able to have the updates done?
If you experience premature belt failure, we suggest that you visit your dealer for proper and complete diagnosis related to your specific situation. If the failure you’ve experienced can be validated, BRP will assist on the available solution.
23- You have a new ventilation system on the 2019 mountain sleds, why is that not being offered as part of this update program?
The 2019 ventilation is a product improvement, similar to the ventilated drive pulley sheave introduced on 2018 units. It was not part of the solutions offered at the time to 2017 units.
I wonder how much the new vents side panel and Cvt cover will be? Thats not including the new secondary with fins. Whoopie, more parts to buy????
Unless you are an extreme rider you can get by with a well running stock G4 850 with minor adjustments that address what generates the heat. With less heat there is less need to ventilate.
No matter what some of the detractors might say, you have to give credit to Ski-Doo for NOT giving up on resolving the issues of the minority of owners, rather than just focusing in on the majority.
Each year they have developed this new sled to make it better than the previous year's edition. While I have been lucky and NOT blown a single belt on any of my 4 sleds, I know some of you just destroy them, and I am glad to see Ski-Doo is still working diligently to come up with a permanent solution to this issue.
Just a quick question, if i read it properly the only way to get some of the updates is to have a warranty claim from last winter! What happens if u had no snow to ride and find out if u have a problem? How is this helping us? I go out and actually get some seat time this winter on my 18 and find out i have a problem am i out of luck? If u cant ride its tough to find out if u have a belt issue
You misunderstood. Any claim that is made will be proved a premature failure or not by BRP. Whether the claim was made last year or if it is today or if it is in the future.
There are a couple levels (call your dealer for all situations):
1.) You have a '17 or '18 and have had no issues:
-Wait til you do because majority didn't so the updates might not help you, only add vibration at low RPMs
2.) You have a '17 or '18 and had issues:
-Made a claim: BRP will look through evidence to see if it is what they believe was caused by vibration or belt clamping force
-Didn't make a claim: Gather up all your evidence and go start a claim. BRP still has to determine if it is what they see as a premature failure
3.) You just bought a '17 or '18 before this data was released but have no way to know if yours is defective. Call your dealer cause this is the gray area. :
-The article says sleds that are registered will need to make a claim (These are ones that have likely been purchased and have been registered with BRP's warranty).
-Sleds that are not registered will not have to make a claim(these are ones on the showroom floors) dealer is supposed to update the sled before it is sold.
4.) Your '17, '18, or '19 is sitting on the showroom floor:
-All '17s and '18s are supposed to be updated since they are not registered. Ask to make sure the dealer completed the updates if the sled is a '17 or '18.
-'19s come from factory with all updates.
I remember in the "old days" when we used to bolt plates on the secondary clutch sides to stop any windage effect. I wonder what the horsepower loss is? Don't get me wrong, I think any attempt at a correction is great and the new venting system is unique but does it address the issue or Band-Aid it.
Does the new venting include filter material to stop the sucking of snow on to the clutches? When in neck deep pow I could see this as a potential problem that could actually decrease belt life.
As to the venting system, which is a product improvement, it is not addressing the problem and not acting as a band-aid it. It is improving it hence product improvement.
If every sled had this feature I am certain there is almost no way the heat would get worse.
Do you honestly think they would forget about snow and its traits when applied to hot clutches?
Any pics?
Bought a couple of 18 in late March still with zero miles. Called the dealer says will look into BUT already getting warranty kits for 17-18 sleds on the showroom floor
I remember that as well, I owned alot of sleds that had windage plates on the secondary.
I believe alot of the heat is induced by the owner, before the sled even leaves the showroom floor.
What do u mean by “a lot of heat is induced by the owner, before the sled even leaves the showroom floor”
2019 T Motion Lockout kit
Just picked up my 19 850 skidoo! :face-icon-small-ton Question for you guys, do you know if the T-Motion lockout kits for the 18 will work on the 19? I was at the parts shop and they had mentioned how a few things were adjusted on the exhaust can when i picked up my HPS Silencer as well as the other 19 updates. I would appreciate any help or opinions on which T Motion lock out kit you prefer!
I'm not aware of any changes to the T-Motion. Should work. I picked up these: https://www.zollingerracingproducts.com/ski-doo/t-motion-lockout
EDIT:
Pics or it didn't happen...
