Z
So last weekend towards the end of the day, my sled seemed to be bogfy around 7800 and wouldn't go above that. Then today from the second I pulled my sled off the deck it was falling on its face. If I pinned the throttle it would cut out for a second then take off but wouldn't go past about 7400-7500. My afr gauge ia showing around 19 at WOT. I triee to adjust my dobeck to richen it up. No luck. Bottom end seems strong but would never excel over roughly 7400 rpm. Several times it would cut out so badly that I would go over the handle bars. Pulled the plugs and they looked fairly lean. Grayish tan and dry. Then a couple times from a stop if I gave it full throttle then stopped it would load up and die...The problem never really got worse or better. It seems to act like it's starving for fuel when its demaded for a lot of fuel. I also noticed that the recoil rope had rubbed a plug wire to the point of exposure. The only thing that changed between last ride was that I changed the weights on the primary clutch. Went from 79 to 76.5 grams. Theoretically rpms should've went up not down.
-Full throttle chops resulted in a cut out.
-Sled never goes above 7500.
-AFRs at WOT are around 19.
All seem like symptoms of running lean. Any thoughts??? My gut says it's one of the following:
-Fuel Pump
-TPS
-Plug wires
Any ideas!?!?
Sent from my SAMSUNG-SGH-I537 using Tapatalk
-Fuel Pump
-TPS
-Plug wires
Any ideas!?!?
