R
installed the 858 rev 2 big bore on my 2013 pro rmk.
first ride out hit DET 7 code, shut off sled and restarted. ran ok but kept cutting out around the 7700 to 7900 rpm mark and would drop down to 6900 rpm. also could only pull around 7900 rpm with clutching set up recommended to me.
Asked RK tek and was told i just have to figure it out. adjusted clutch set up and went out second time and reached 8100 rpm consistently but still had problems at the 7700 to 7900 rpm. checked plugs and found exhaust side had a bit of carbon build up so changed the plugs
third time out, adjusted clutching again and hit 8300 on some pulls but still cut out around that 7700 to 7900 rpm when i would get into that range. checked plugs again and they looked a lot better, exhaust still had what looked like a bit of oil on it but clutch side looked perfect
sled would not stay idling when started up and would have to hold throttle a bit until it warmed up and then would stay idling for a bit. took sled in to have idle checked out and bore scope and compression test to make sure the DET 7 code and cutting out didn't do any damage. they said my TPS was only at 4 watts so they zero'd it and reset it to recommended 9 watts so that also might help with some of the issues i've been having with the cutting 7700 to 7900 rpm. Bore scope looked ok and compression was 120 and 130.
Sled still idled rough and went out for 1st ride after TPS adjustment made it about a km and sled died, shut it off and restarted got another km and self died and would not restart. checked plugs and they looked a bit white/lean so towed sled back to truck and stopped in at sled shop in golden and bore scope show scuffing on cylinders.
Talked to boon docker today and he said that adjustment of the TPS should not affect the mapping of the control box.
So i'm scratching my head and don't know what to do??? could i really of toasted my cylinders in 2 kms on the trail heading in? wasn't holding it full throttle or anything..
leaning towards just putting it back to stock.
any suggestions or experience with this?
Cheers.
Cheers.
