Did some riding in a field by my house today,just putting on miles.Elevation is low,only 2100 ft. and +8 degrees celsius.Very low and very warm for a turbo. Sled was good going down the trail and building boost as I was on and off the throttle.I hit the field and worked it thru the rpm band only to get high EGT temps..as expected.Turned out the power jets and tried again.Builds great boost across the field..8-9# lift the skis no problem.Plugs are good,clutching is good(engagement is 4600,gonna lower it a bit) sled is running well.Did this for a couple of hours until the powerjets were 2 full turns out and the EGT temps were ok.Boost is still around 8# and track speed is 70 mph(which means nothing as it is on corn snow on flat field).Running 100% VP 110 fuel with a little amsoil in the tank for the first tank or two,until I get some miles on it.Stayed off the rev limiter and no knock sensor codes or any codes. Pretty happy with everything so far,considering elevation,temp and new sled.Never held it wide open long enough to build max boost or track speed,obviously. This is a strong sled and I believe the kit is gonna rock.
When I had it on Brohm Ridge,the powerjets were all the way in @ 5000-6000ft elevation and I was makin short steep pokes when I got 67 mph at 8# and 8000 rpms. I got the numbers from the recall on the sled,which I reset b4 every climb. Once again,I believe this is a strong kit, and so, far real easy to use. Only thing I noticed is that you will have to adjust your idling screw when you turn the powerjets out this much.Will not be an issue in the mtns.
Hang in there boys...as I am very impressed so far.The real test will come when it is broken in and I get it to the mtns.BUT,REMEMBER,this is a turbo on an engine that only has 150 miles on it.IT WILL GET STRONGER!!!!!! I like to ride big hills at full throttle, so time will be the real test.
