F
FBM
I have a 1995 Phazer II. Putting a DG pipe on it. Called DG. All they could remember is that it should run 7300 rpm. Going to run it at 1300 ft in the flatland. It has 89F weights with the pink/blue/pink (hi alt)primary spring. Secondary is a 38 with a pink spring. Will this work? If lighter weights are needed, which ones? 8DJ are 6 rams lighter with no rivets?
