With all the talk of going with lower bars, I started looking around and doing some research. Read a ton, watched a bunch of videos and finally decided to pull the stock Pro Tapers off and try a set of Dan Adam's Next Level Bars.
So others can compare, I'm just over 6' with my Klim boots on and have about a 36" sleeve length on shirts. The Next Level bars are about 1 1/2 lower then the stock / standard Pro Tapers. They also have a little less "pull back" or grip angle then the Pro Tapers, basically the Next Level bars are a little straighter.
I also spoke with Dan about his bars and he suggested cutting about 1 3/8" off each end. He said by narrowing the bars up a little it tends to lessen arm fatigue and improve overall control.
Before mounting the bars up, I took a bunch of measurements where I thought it felt the best. I stood on the sled, knees slightly bent, simulating a neutral riding position and closed by eyes. Had a little help with this and several measurements were taken. Amazingly enough the measurement actually came in a little lower then the stock bars.
Once I got the bars mounted up, I ended up cutting off about 1 1/4" off each end of the bars.
Once the bars where on, adjusted and tightened up you could immediately notice the difference. The bars actually feel stiffer / more ridged, when pulling the sled onto it's side. Again this is only in the garage so far but you can feel differences already.
It's definitely different and I'm anxious to try it out!!!!
