H
Well now that the season is almost over I finally made it out to try my new Garrett setup on my 800ho. This year I changed from the mitsu evo turbo to the garrett 2860. I went from a mechanical oil pump to a electric. I moved my afr from post turbo to pre turbo (same spot turbo performance has them in their kits). I added a cold air snorkel. I think other than some small plumbing changes of antifreeze and my charge tube routing thats all I changed.
Last season I was riding it and it melted the one piston so I decided to do some upgrades while I had it apart. With the mitsu I was running 360 mains, 15 pilots, needles in 2nd from the leanest and power jets at 2 1/4 turns out. I decided with the garrett I would bump it to 400 mains to go on the first ride. After going up the trail I couldn't believe how well it was running. Instant throttle response. It felt like riding a stocker on bottom and was pulling hard up to 1/2 throttle or so. I couldn't really go much more than 1/2 till we got on top and it opened up and it was at about 8500 ft. elevation. First run at the hill I made it maybe 50 yards at full throttle and it went way lean (around 14.5 on the afr). So I opened my power jets to 3 turns out. Made another similar pull and it dropped to 13.5. Opened them to 3 1/2 turns and it killed my throttle response in the bottom to mid but dropped my afr to about 13. I dug through my jets and my two biggest jets were 470 and 480. I threw those in and put the 17.5 pilots back in since the thing wouldnt idle with the 15's. I left my power jets a 3 turns out to test it. I was seeing about 12.3 initially but would creep to 12.5 then 12.7 in a short pull. Not wanting to smoke another piston I didnt dare keep it open very long.
It seems everyone is running in the 360 to 380 range and having good luck. What am I missing here that is making this thing need so much fuel? My fuel pressure was showing around 15-17 psi. Boost was 10 psi. The way it is now I need around 520's to be able to close my power jets a touch and get my mid range cleaned back up.
Any thoughts? Thanks in advance!
