B
Sorry but i doubt I will get an answer in the oil delete thread since I cant even read page 4 because I am standard member and maybe someone else will get helped from this. My engines crank went bad, bad cage bearing on the flywheel side. Anyways I am rebuilding my engine and when I bought the sled it came with the oil delete and since the guy I bought it from seemed to be a hack I doubt he did the oil delete correct. Basically after everything I have read the best thing to do is drill a 45degree hole from below the center crank bearing sort of by a locating pin into the water pump shaft housing sort of up towards one of the existing oiling holes. Could someone confirm this or maybe explain in better detail or is there even a writeup? I can make a better tutorial if there is not one but I really wanna get it right. Am I over thinking it and is just having a hole going anywhere from the mail crank case to the water pump shaft housing enough? I attached a pic I found in the other thread in here as well, someone please clarify all of this for me,thanks. The picture below is confusing, anyone have a better pic? How do I dril the hole and exactly where do I drill it.
