I'm looking for someone to work on my 07 Summit 800, the local dealer here in Fairbanks is not accepting anymore snowmachines as they are busy with boats. Any feedback on Tanana Adventure Sports in Delta?
My 07 Summit 800 has been acting up the last two rides, it will load up when climbing or on flat when under load. I seems to be using more fuel and oil, and smokes more.
I've checked the carbs, they look clean although I didn't take them apart.
Compression was about 140 psi both cylinders.
Cleaned RAVE valves, they were oily. All lines look tight.
Checked DPM unit, solenoid was working. All lines look tight. There is one thing on the DPM that concerns me though and the shop didn't know anything about it, is on the vent tube outlet there is a "vent jet" that shows in the parts breakdown, but I don't see one in mine. Is this a "tuning" thing? The shop had no clue plus it's not listing as an individual part so you have to buy the whole DPM. Maybe mine had it and I lost it when I took the hose off, it's possible. There is also one under the solenoid that you can buy individually.
I looked at the throttle cable adjustment and the oil cable adjustment. I'm a little confused there as should the pump lever be moving before the throttle takes up slack?
Anyway I've about run out of options, I've posted on dootalk and snowest but so far nothing's worked.
Being that I live in the Fairbanks area. Were I to ever own a Skidoo I would only take it to TAS. I'm not a fan of the local shop and the guys at TAS are more than happy to help people out. A buddy of mine has an 07 summit that has spent almost as much time at the shop as it has his garage and TAS has bent over backwards to get the machine right. The problem with his is the damn TRA clutch they put in the 07 is a POS. 06 was the magic year to buy a summit, in 07 they took a good thing and decided to "make it better".
