We have all read the gushing over Lectron style carbs on 2 strokes and I have been an advocate of them for years. I run two on my dirt bikes, all good.
So what happens when you want the same improvements on your 4 stroke single 450 ?
Been waiting and asking. Now I have one, no I haven't ridden it yet. So no gushing or thumbs down yet.
I have been watching and waiting for someone to post on this subject. Now you can read a good test. search for MOTOSPORTZ, Vancourver WA company here in the NW, go to his products, hit lectron and read his testing on a yz450. All what I wanted to hear.
$450 give or take for a 40MM LECTRON with needle and choke setup for my WR450 Yam with a cable and single cable MOTION PRO throttle and rubber cover.
So, you set aside an almost 3 lb Keihin Carb with three cables and replace it with a way too simple single cable & twist throttle. Fits the carb boot and air box boot real well. Goes on and off the bike with about a 1/10th the effort of the stock setup. It will swivel down for needle adjustments on the bike with tank on out in the field with ease.............nice. The stock carb is a turd basically. I have almost as much money in parts and needles and diaphrams, and jd needles for my WR250f as I spent on this carb if it works.
So what do I expect...............it'll work. Not sure how well, time will tell.
Will it ice up as is, yup, did my keihin ice up, fixed that.........now again.
Will it do 50 miles to the gallon no, 31.2% more hp.....no. I won't need a dyno to tune it.......cause I don't have one. I'll report later. Biggest issue is I made about 51 changes to my snobike this fall, now I have to gather all that up and ride and sort out the tuning and dinking around.
