i was out gettin my m7 ready for a ride, you know toppin off the oil, checking everything out and such and i decided to clean the sheaves on my clutch. so i started it up to run a scotch bright on the sheaves while it idled(im sure not the brightest thing to do but im sure im not the only one to do it) and when i put pressure on the scotchbright pad against the sheaves when it would start to bog down i could here a nocking noise coming from the motor but its fine if i take the extra drag off the motor.
i do have high compression heads and my house is only at about 4500ft so i dont run it much down here. but i've never heard anything when riding at 6000ft+ where i normally ride and it runs fine. a week or two ago i had the y-pipe off to get a crack welded and checked out the pistons and such while it was off and everything looked fine. no sign of damage to the pistons or cylinders.
so could this just be a bit of pre-det. knock cuz of the low elevation or does it sound like there could be something major wrong?
thanks
brandon
thanks
brandon
