1] I noticed in Joes video the sled revs very quickly - Is this a concern for the etec?
2] I've heard that this can put the engine into limp mode.
3] Also, what about over revving?
4] What are the concerns and how are you guys dealing with this?
5] I've heard this too can put the engine in limp mode and also cause problems with reeds.
6] What can a guy expect for reed life?
Thanks,
-Fack
Hi Fack.
Hope y'all dont mind me answering this way...
1] Did you hear the engine stutter in the video? :face-icon-small-hap The mountain ramps combined with the start force of the primary spring, load the engine enough to keep the ECU from detuning.
2] I have other primary springs available to lower the engagement and load the engine a bit more off the bottom end. (if needed)
3] Aaen law - flyweight determines engine speed.
- If need lower engine speed - then add flyweight
- If need higher engine speed - then reduce flyweight
- 1 gram = approx 150~200 rpms to give a push off the dock so to speak.
4] Look at #3
5] Depends on what year of 800etec and what model at what engine speed the ECU will detune. Ideally you should be prepared to either change the clicker position after you check what the flyweight does for your rated engine speed. That will give you an indication on what flyweight gram change you "may" have to do - if any at all.
6] Reeds - backfiring from lean will cause reed petals to chip. Far as I know overrevving will not cause reed petals to chip/crack/fray etc. Lean backfires/chuffs/pops, oh yeah you bet. (personal firsthand knowledge)
An old study...
2012 800e's were one of the worst for reed petal failures and people think it was due to the reeds themselves - in a way, yes that is true. The reed can't take the lean backfires and bog that particular engine has dished out.
The root of the problem is
(all etec's stock run lean)the 2012 800e runs leaner compared to other lean 800e's to where you get that 7500~6500 intermittent bog. Ok, solve the lean bog by the ECU in 2013 adding percentage more fuel.
A 2012 with a fuel bog problem can be solved with a few methods, one is an economical fuel controller. There are a couple of guys on dootalk that have done outstanding thoroughly authenticated first rate tests to produce facts to reveal what's going on in that particular engine. Now this carries over into where engines by some way start to breath more air (porting & big bore) and the engine is setup to run lean beyond the current fuel injector flow programming for potential backfire = need more fuel.
