I sure wouldn't recommend running those on a 155 HP plus 800. They were cracking in the sheaves down near the center with lower HP 800's years ago.
I have two of them I ran with no problems on doo 550 fan summits, but only 70 HP on one and 85 HP on the mod. The problem is all that pretty fluting on the sides of the sheaves. They went overboard with it and weakened the clutch, also I believe why the company folded. It was a great clutch except for those dang flutes. My 550 mod fan Summit went where all my buddies liquid cools could go in the mtns. with that clutch.
Like was said before you have to prewind the spring to get it to backshift. More prewind more backshift, spring with more lbs = more backshift, more lbs spring has thicker wire.
What I would recommend is to go back to a QRS doo secondary and put a ShockWave adjustable cam in it. In 45 seconds you can change your helix angle (cam angle ) from 38 degrees (lots of backshift) to 45 degrees (lots more acceleration) etc. and come up with the best setup for you and your sled very easily.
Good Luck
