Are you asking if you stay at a set elevation and increase boost what hp it increases by? This would be somewhat dependant on the elevation. The higher you go the less headroom the stock turbo has. The stock turbo realistically can handle a constant 17-18lbs. If you are at an elevation that requires 10lbs to make rated power you could in theory add 60-65hp till the turbo runs out of the ability to compress air past 17-18lbs. If you are at an elevation that requires 15lbs, say 5000', you only have a couple pounds of potential boost left. This is why something like a BD 2.0 becomes less effective the higher you go. You can't get around the fact that the stock turbo physically can't produce more than 17-18lbs at elevation which is why something like the Evo mountain reflash uses the elevation maps in conjunction with timing to make more power with better fuel, and not go past the max useable boost number.
Otherwise boost lbs are irrelevant, stock or not, it makes whatever its rated power is all the time by controlling the boost electronically, until the max useable boost is reached then it just makes heat after that.
