N
I got a Nytro MTX with MXC kit with head shim. Run at about 2000 feet but head out west about 3 times a year. I guess I need to start by making this thing run aT 2000 FT.
I haven't road it yet, just got it together. I'm just worried that when winter comes i'll be chasing the set up around.How much boost your running?
I had Dustin at Outlaw set me up for altitude and its been perfect. The kits are a little pricey but well worth it. The expensive parts like the weights and helix are adjustable. All you'd need to do is order a couple extra springs and with the altitude instruction you'd be set.
Did you install the MCX your selfI got a Nytro MTX with MXC kit with head shim. Run at about 2000 feet but head out west about 3 times a year. I guess I need to start by making this thing run aT 2000 FT.
My kit came complete with clutching installed for the T-kit. I ride at 2000' for the most part and head to the hills 3-4 times a year and ride at 6-8,000'. I change nothing except boost when I head west. One of the many benefeits of a t/c is the nominal loss of hp with altitude so I'm not sure why you would need to change the clutching a bunch. I believe there is about .5%/1,000' loss with t/c vs 3% without t/c. So that's about 2% loss in the 4,000' change in elevation from 2,000' to 6,000'. That's about 5.4hp loss if my numbers are correct. Considering the limited exposure to the higher elevation, mountain riding, is there a need to be re-clutching for less than 10hp loss on a 270hp engine?
