P
Just wanted to show off a little project we have been working on, this is for all those guys rocking the C3 heated bars. We have come up with a case that mounts in place of the front number plate. We have built a heat exchanger that sits in the bottom of the case and is plumbed into the heated bars system, so circulates 90c fluid through it. this helps remove heat from the bike, not always an issue but it does do that and it also warms up your sammichs', gloves, toques and unthaws your goggles. We have got 4 full days so far and all results are good. Its a pretty easy plug and play onto your existing c3 heated bars. it could work on other heated bars but it will need to have different fittings added. if your handy you can likely make it work with your aftermarket thermostat as well if you don't have heated bars. Looking to have the available early in the new year.
