Grippers vs 19 Cat skis
CO 2.0
So ran 19 cat skis all winter long on my alpha and MC. Had grippers on my 18 all last winter. Think the 19 cat ski is a huge step up from all previous Cat skis. They look so similar. But after today I am back on the gripper train.
I put one grippers ski and 19 cat ski on my alpha. Road it today in 12" of fluffy pow on top of rock hard snow. So there was little push back and some unpredictable nature of the snow. This is where I noticed the biggest difference on why I like the gripper ski so much. I tried to throw every maneuver down I could on both skis. The gripper was the clear winner for me. The 19 cat ski has wierd spot when you have it on one ski that is grabs bad and makes for tough steering and less predictable nature until is breaks free. Where the gripper easily slides past this grab point and slides back and forth easier. Was a lot less taxing on my shoulder and hand on that side today.
The gripper is lighter. They look similar, but the keel on the gripper goes almost to the tip and tapers down where the 19 cat ski keel stops well before the tip. The 19 cat ski is longer in the rear and the carbide is a tad longer. It tips up more in the rear. The front tips up more by a good margin. The loop on front of the cat ski protrudes forward and is larger where the gripper is smaller all around and curves back quicker. The gripper flexes more at the tip.
So yes I was surprised to see the difference. Didnt think it would be as much as it was. On trails the cat ski is better as it grabs to corner better instead of sliding out as quickly. But Id take that downfall of the gripper compared to how much more predictable it is in one ski conditions on sidehills, donuts, etc. I purposely swung each ski around a ton doing all tech maneuvers to try to make each ski mess up and catch itself in different spots. I knew the only way to compare them equally was to run them both the same day on each side in the same snow conditions
rR6NWAP
Yes that is the main reason why im switching both sleds over to grippers.
Haha,
That's exactly what i was going to do!
I'm glad u posted. Save me the trouble.
Grippers back on in a few minutes.
Now, did u notice the track washing out on sidehills with that crusty layer? Mine was so bad last weekend, i just quit sidehilling anything over 30°.
Legends ZX2 SR [emoji58]
Think you can modify the stock skis to work better? Id like to keep the stock green skis on the 2020
Sent from my Pixel 3 using Tapatalk
Also if you can would you mind weighing the stock ski vs gripper
Track does wash out in that type of snow. Id rather have rode my MC today. I'll weigh the skis once I get the other pair of grippers for the MC.
Damn, i just swapped them. I honestly thought about weighing them. Grippers are definitely lighter.
Keel is about 1/4" shorter on gripper. (Depth)
Found a post that has a pic of gripper weighing 6.25 lbs with the spindle bolt and a skidoo rubber. What does a stock 19 ski weigh?
I swapped them on the sleds. My Hawk had the grippers, now it has the 19's.
Because u seem like a nice guy, i just pulled off the ski. I got exactly 7lbs all hardware.
rR6NWAP
yes! exactly what was wearing me down with cat skis. bigger gym hitting dudes like Caleb K. won't notice as much.
and the loops sticking out that extra inch up front, just uncalled for :yuck:
PM me , whoever wants to sell their '19 NEW or LIKE NEW stock skis for a reasonable price!!
CO 2.0, you have any access to the slydog Attack? They are heavy, its the only draw back, i think 1.5Lbs more then the gripper. I really liked the Attack over the gripper. The one slight problem I saw with the gripper this year was in some heavier snow conditions the gripper would flex too much on a sidehill and almost act as a brake. The gripper is still the lightest, best mountain ski out there. Weighed the gripper 6lb 3oz with all hardware, 19' cat ski 6lb 15oz.
57mi today.
Grippers are definitely easier to steer. They do push a bit more also.
No complaints.
I like grippers, they work well on my 18. Plus i paid 150$ for a gently used set. They other day i saw a pair of take offs for 200$. I really like the color combos slydog is pushing with the new attacks but man they are a pretty penny.
So out of all the aftermarket skis, slydog, grippers, mowhawks, etc....... Who’s will lessen steering effort the most on a 19 Alpha?
