P
Anyone have a preference on these? I've got both sitting around, not sure which to run...
I've got a selkirk kit and a generic e kit.
now that i've got my Selkirk coolant heated bars, what are you guys doing for insulation of the bar or are you insulating the bar? I'm assuming there is a significant amout of heat loss from the bar rather than the grips.... thoughts?
As everyone else has said, the coolant bars are better. I had no issues losing heat and they were a bit more consistent than the electric bar heaters I've used. More expensive, but with your t-stat (assuming you buy a good one, like C3) you can turn them off in the summer and not mess with the plumbing. A few of us will run a small diameter cork inside the bars for the winter to make the heating a little bit better. I put a bolt all the way through it so that I could easily remove it if I needed to. Works great.
We used to use cork inserts in our handlebars on snowmobiles to help the grips retain heat. We use the same methodology on our snow bikes too. (obviously this would only be used for electric heaters, not coolant)I'm not getting the cork modification? I could just be a little slow today.
I made my own coolant heated bars (search the threads on here, there's multiple types/instructions) and they are awesome.
Had to change the style of bark busters I run as they can no longer insert into the bar ends.
