anyone know the actual ratio numbers when changing from a 8 to 7 tooth driver.
Can't find it anywhere
Some of it comes down to available sprocket sizes also.
According to the calculator the closest you could get to a 20/49 8 tooth set up using 7 tooth drivers would be,
22/48 (2.18 ratio) with 7 tooth drivers would be approx 1.26 mph slower at 1 to 1 clutch shift out.
22/47 (2.13 ratio) with 7 tooth drivers would be approx .3 mph faster at 1 to 1 clutch shift out.
I would think that the 22/48 7 tooth would be just about ideal on a mountain sled, if your goal is to stay near the 20/49 8 tooth drive ratio.
just for learning purposes , if you had 8 tooth @ 2.52 pitch they measure 22.68 cir. 7 tooth 3 inch pitch 21 inch. 22.68-21/22.68 gives 7.4%reduction. Drivers never measure the teeth x pitch and Avids run even smaller. I have the actual Circumference written down at the office and recall them near 20.5 cir. I run 2.4 gearing with my 7 tooths and am right at 1-1 ratio clutch shift on a Doo w/ 3 inch
With 21/47 gearing you will be running a 3:1 belt to ride ratio.
If I run 21/47 with 7 tooth it would be about the same ratio as running a 20/50 with a 8 tooth. So it would be geared down slightly from the stock 12 2.33 to 2.52.
The stock 14 gears run a higher overdrive than this would
