G5 auxiliary 12 V power plug
High Voltage
The G5 seems to have gone to a three wire power plug. That’s on the blank under the dash to hook accelerate power to. Our dealer can’t seem to find one or even a part number. Anybody have a part number?
Found this on the part description.
Use the red and black wires to power a 12volt accessory when the sled is running. Use the grey and black wires to power a 12 volt accessory when the high beams are on. Tape over the extra wire that you aren't using.
I bought a heater visor accessory plug that I will cut the leads off of and tie whatever into it.
But there is also a 2 wire plug tied in behind the gauge that the USB plug ties into. I also bought a gen 4 splitter so I can feed other the USB port and my trailtech.
The 3 wire plug has red/black/ grey wires.
The red and black are constant, but the grey is switched hot with the high beam fyi
