Any suggestions as a starting point for air pressure and compression and rebound settings on a Nytro? I am about 200 lbs plus gear. I will probably start at 75psi air pressure but I am not sure about the other settings. Any tips on tuning these other than trial and error?
Thanks
but I want a more compliant ride like the Float 2's, which is why I moved up from my original Floats to these Float X shocks.
200. I would have guessed much much less.
M5
since all depends on what kind of ride you like (softer/stiffer) and take ambeint air temp into consideration (ex. if its -20 when you set shock pressure you will need to re set it for a +5 day) start at 65 and work your way up. as for rebound and compression. There is ton of fine tuning that can be done to find your exact likings. remember for every action there is an opposite reaction. crank up the compression damping for shock that will not compress as easy most likely making it sidehill or carve better but rough on trails due to less shock compression and vice versa. Rebound is easy, find some whooped out trail and run back and forth down it. turn the rebound right up and then turn it down after each pass until the sled does not bounce around and the ski will "hug" the ground. not enough rebound will almost give you a bottom out feeling cause the shock will not extend fast enough and be ready for the next whoop and it will not use full travel to absorb the shock. thus transfering extra impact to the rider.
hope this helps,
Because of the added reserviors the X's can run a lot higher pressure. In my standard Floats I was running 75, in the X's I run 105. I would start with 100 psi, compression 6 clicks out and rebound 8 clicks out. When I first got mine I started with the adjustments in the middle and changed one adjustment 2 clicks at a time until I found the settings I liked. It's pretty hard to notice a difference just moving 1 click.
