Evo 3 16g turbo
turbo800
850
216
Northern,UT
Yup, lots... I built my own kit using this turbo. CPI also uses the same one for their REV turbo kits.
snowmanx
2,163
442
83
54
Polson, Montana
Cpi used them on the 900 cats as well. I am running one on a 04 900 cat, works great, but like stated, need the high pressure oil pump, and run an oil gauge to make sure you always have oil pressure to the turbo. If you loose oil pressure and don't know it, you;ll toast your turbo right away.
turbo800
850
216
Northern,UT
Snowmanx, are you using the CPI graylor pump? I'm looking for a new oil pump that doesnt put a drain on my electrical system.
T
Todd H
95
11
8
Oil pressure
How much pressure does this turbo need? I've got one too and I really like it, but was concerned with the oil pump as well.
Spaarky
3,429
1,345
Chester, SD
if your running a Garret yes, but a Mits no. I wouldnt recomend not running with oil pressure, but it wont burn up that fast. I have taken down oil pumps and not realized it. Also.. road it into town with no pressure 4-5 miles. No ill affects to the Mits...
