I have ES and 7s gauge on a '23 Boost. They both worked everytime until at the very end of the last ride I stopped and hit the kill switch but left the key on. All of the sudden the 7s Gauge turned off and when I tried to E-start it it tried to crank a few times but wouldn't turn over and the gauge wouldn't come back on with just the key on. I pull started it and the gauge came on and worked just fine while the sled was running. Got home and went to unload the sled and hit the E-start and it fired up. Got it unloaded and now it won't even try to start with the E-start and the 7s gauge won't come on with just the key on. The sled starts and runs everytime when pull started and the gauge always comes on when the sled is running. I checked the battery connections and everything is tight there. I checked the voltage on the battery and that is fine. I checked the 2 fuses above the battery and they are fine.
Anyone else seen this issue? What should I check next?
