I want to share my experience with you all...
The sled was just over 2 years old when I bought it in 2010 and warranty was out. The first ride I had with it, I noticed that all lights was flashing a couple of times and figured it was just my eyes that was wrong... Second ride didn't end that well, in the middle of nowhere it suddenly went dead! Completely, everything! :face-icon-small-sho
After some research i found the fuel filter clogged and it started - yei! I packed my tools and pulled the starter, gave some throttle and off I went for around 50meters... Then it stopped again and some smoke (electrical burned smell) came out. I was so angry that I just started it and ran it over and over again until it went dead :face-icon-small-con
Found the wirings to ECU melted where the ECU is supplied from the voltage regulator. To make a long story short, I towed it down and went to a local dealership with it. Previous owner helped me with this and we managed to get it as a claim :hail:
THE ERROR: Voltage regulator went down and supplied the electrical system with under voltage, causing the ECU to load lots of Amps, which burned the socket and wire to ECU. See picture...
Had to change voltage regulator, ECU and wire harness! Price in Norway was 5000,-USD!!! :face-icon-small-con
I made a solution which will save me for buying a new ECU if it happends again, see pictures. It is easy, cheap and helps your wallet! I use 5 Amps fuses, but are thinking of changing it to 3 Amps.
Since this, it has runned nice
