There are different types of green loctite. The stuff cat uses is 640 hi temp high strength retaining compound. I use red when i put it back together.
This was a great thread. I just re-read most of it. I ended up with the Speedwerx H5 170/270 secondary spring and liked it better than the stock secondary spring.
I see Vern went to the same Speedwerx H5 spring but the rate is 150/270 and is as happy as clam as well.
So, I have to wonder if I might be even happier with the 150-270.....spring vern is using?
Are there any new updates on the subject?
Not a 150-270? That's what Vern has...Vern, I went ahead and ordered (and received) a Speedwerx H5 150-250 secondary spring.
I think I will leave my 170-250 in for the start of the season so I can try it before swapping springs so I can see if I can feel a difference.
Also, I see you have a 2.42 gearing (27 tooth upper) on your belt drive. I have 2.63 (25 tooth upper). I REALLY want to try to try going with at least a 26 tooth upper gear. I think I am leaving a lot on the table with my current gearing.
Thanks, my post now will make people question my reading comprehension...Oops- fixed the numbers - I have a 170/270 currently and bought a 150/270 to test once I get a couple rides under my belt this season.
I went ahead and ordered (and received) a Speedwerx H5 150-270 secondary spring.
I think I will leave my 170-270 in for the start of the season so I can try it before swapping springs so I can see if I can feel a difference.
Since that other post popped up, Thought I'd pull this back up for an update on what folks have ended up with. So let's hear what everyone ended up with.
I'm still running the 150/270 h5 spring, with 110/290 slp primary, stock 68g weights, stock helix, riding 6-9k elev. Loving every minute of it. Well over 1k miles on this setup, these exact springs actually, Works great in the trees, no bogs, backshifts great pulls like a mofo at 8100-8200 rpm all day.
this year I installed a y-pipe and did the track "mod" to my 2.6" and she's performing like a raped ape to the point buddies have accused me of piping it or something over the summer. One buddy has a twin piped 910 bb pro, really diehard poo guy, and he took my sled for a rip and came back and first words out of his mouth was "that m-effer is fun!" Real happy with how she's running.
