The jack shaft is flexing putting undue stress on the bearing in the chaincase
So where is the best place to put the new pivot pt?
Challenge back at ya RKT.
Of all the critical dimensions between the primary and secondary: 1. Center to center, 2. And alignment of the three rotational axis, none of these appear to be worse than a typical clutch, chassis and engine relationship, at least during steady state, quasistatic loading.
But, going back to the direction you are taking, the engine appears to have a higher degree of latitude to move, which MAY introduce dynamic, vibrational related forces.
Hmmmm, so not really a challenge but some out koud thinking.
All tcl Cats don't have issues though?
Kelsey, for your 5 dollar fix, are you just "strapping up" the TCL to the frame to unload it a bit?
I think that ALL do have this problem. They would have to.. You have a giant lever around a sole pivot point..Leverage is at work here.
--Seems like another motor mount would be the best overall solution as there would be no pivot point on the TLC and it would also reduce wear and tear on the rear TLC mount
Shoving some rubber between the tcl and aluminum frame rail up front?
