O
Who's running an aftermarket belt deflection adjuster? Ones I've seen available so far are Osp, slp, bikeman, thunder products, and CPC who have two available. Floating and non floating.
Any pros and cons? I like that you can use them to take the belt off easier. Also like that you can fine tune your deflection with fine adjustments.
Anyone running the floating style adjuster? How does that work? How can it float and keep proper deflection? Do you still set your initial offset with the 1.485 bar?
Any input is greatly appreciated
