J
Joemt
I removed the Cylinder from my 2002 800 RMK due to the broken VES bolt with the broken Easy out in the broken bolt (different thread).
1. I got the cylinder cleaned up and I used spray gasket remover (stuff works good). But I wasn't sure about using it on the bottom cylinder gasket on the block due to over spray???? What works? those gaskets are on there like cement.
2. How in the hell do you torque the two cylinder nuts in the front of the sled???? Is there room for a socket and torque wrench?
3. Embarrassing Question: Like a dumb ***, I started on the wrong cylinder, meaning I loosened the nuts. Do I know have to replace that gasket even though I did not attempt to remove the cylinder???? I was so mad at myself.
I just tightened the nuts back up and still need to be torque to proper specs.
4. I also noticed some type of sealant at the top of the head bolts...real light blue in color. What is this stuff and how should it be re applied when re assembling?
Thank you
Joemt
Thank you
Joemt
