Cracked Pro hood - repair options
W
Wood
297
168
I just picked up a '13 Pro LE with the white hood and there are a few nasty looking cracks around the gauge/console area. I plan on selling it in the fall to buy a '16 but would like to fix these cracks to help resale. Sled is otherwise mint. Pretty sure i read that the material is TPO...what are my options?
wellfed777
2,226
412
83
Oregon
take it a part so you can get behind the cracks then gently grind a V under the crack then glue with a flexable 2 part epoxy i've used one for years
its called duramix #4031 you can buy it at an auto paint store
for added strength put some strips of plastic mesh in the glue
if your careful and take your time you can hardly tell its been fixed
and its really durable and will last
tip = use blue tape to hold the crack together while glueing
good luck
W
Wood
297
168
Thanks guys. Trying to avoid the 'Frankenstein' look if at all possible...lol.
Anybody have experience plastic welding one of these hoods?
wellfed777
2,226
412
83
Oregon
i think the problem with welding is it won't be flexible then it'll crack after awile the glue is very strong and flexible
the epoxy is $35-$40 but the the gun is $50 used
the best option would be to borrow a gun or share the cost with some other
sledder
M
mt.aero
122
127
Steamboat
For plastic, especially those more brittle plastics, drill a small hole at the very end/ends of the crack. It helps to stop it from spreading. It's not the prettiest thing, but neither is a longer crack.
ditch1000
476
88
Fort St. James, B.C.
You can weld them no problem... The material if HDPE!! Just gouge out the cracks, use some aluminum tape to hold the cracks together and stable and then fill the cracks, sand it up, paint it, and it'll look like new. Also if there is a good plastic shop in your area, they'll do plastic welding as well..
I purchased as Mini-weld airless plastic welder from Mechanics Tool Warehouse a couple years ago; it only cost $160 back then... With having toys, I have used countless times and it has paid for itself over and over...
I welded my hood once and side panel as well; it has never broken since!!
https://www.mechanicstoolswarehouse.com/Mini-Weld-Model-7-Welder-P179844.aspx
mountainhorse
18,606
11,814
West Coast
www.laketahoeconcours.com
The painted hoods (white, blue, etc) are TPO...ThermoPlastic Olefin...
Take it to your local body shop... and they can repair and paint it for a decent price if they are good guys.... those hoods are pricey.
Otherwise... you can repair it... Google TPO bumper repair... and check youtube as well.
Good luck.
tuneman
1,167
1,205
Minnesota
www.everettsports.net
I cracked up my hood this year too. It's a black hood, so it's HDPE. As stated earlier, any other color is TPO. I'm cheap, so I just picked up some CA (superglue) at the hardware store that comes with a primer pen. I think Loctite makes it. It's supposed to work on polyethylene. It bonded it but we'll see how it holds up...
mountainhorse
18,606
11,814
West Coast
My paint guy recommended this stuff for basic repairs
http://www.amazon.com/U-Pol-Products-7061-STRONGHOLD-Plastic/dp/B00397NQN4/
You'll still need to paint it.
He also suggested using more mesh/filler on the backside.
Prep is Super important... you need to clean, clean, clean before the repair
<iframe width="800" height="450" src="https://www.youtube.com/embed/No4G88iqDss" frameborder="0" allowfullscreen></iframe>
<iframe width="800" height="600" src="https://www.youtube.com/embed/0gnpavYvv08" frameborder="0" allowfullscreen></iframe>
L
Jan 7, 2013
80
18
8
34
Casper Wyoming
THIS ^^^ regardless of weather you epoxy, bondo, super glue, zip tie or whatever. . . a hole at the end of the crack is the only way you will keep it from spreading.
