Went riding last weekend and noticed that my sled was only getting 7600 RPM when in loose snow. Checked it on the trail and it was spot on 8150 and would hold.
So yesterday I checked the primary and installed a new spring. (SLP Green pink 160-320.) I also cleaned the power valves and they were a bit gummy but no holes in the bellows. Also changed plugs and made sure the connections were clean.
So went riding today and sled ran great up until we got to the powder. Low and behold same thing... this time 7400 in loose and 8000 on trail.(Higher elevation)
I only have a little over 600 miles on my 12 pro 163 and last winter I had changed over to my spare because my first belt had some cords ripped out. (I assumed from snow coming through the foot well and my belt slipping a lot.) Changed the first belt when I had about 400 miles on the sled so I don't think my belt is the issue. Also have the oiler turned up about 3 turns and the sled has no change when I switch the ethanol plug around. (Running 91 non ethanol.)
Its coming down to maybe injectors? Or I got some issues in the secondary. The problem got way worse when I ran the sled in deep snow for a while and it seemed to really get heat saturated. I saw rpm's as low as 7100. I haven't been inside one of these team clutches yet so if anybody has some ideas for things to look for it would be greatly appreciated.
Sorry for the long post but I wanted to give as much info as possible.
Thanks!
Edit:
Also sled ran great last year at the end of the year. I was normally pulling 8150 all around.
Thanks!
Edit:
