Climate change
Skidoox
34,109
65,415
Provo, UT
Before believing the "global warming solution" myth, consider what you must give up when petroleum-based products are no longer available.
One crisp morning in Sweden, a cute little girl named Greta woke up to a perfect world, one where there were no petroleum products ruining the earth. She tossed aside her cotton sheet and wool blanket and stepped out onto a dirt floor covered with willow bark that had been pulverized with rocks. “What’s this?” she asked.
“Pulverized willow bark,” replied her fairy godmother.
“What happened to the carpet?” she asked.
“The carpet was nylon, which is made from butadiene and hydrogen cyanide, both made from petroleum,” came the response.
Greta smiled, acknowledging that adjustments are necessary to save the planet, and moved to the sink to brush her teeth where instead of a toothbrush, she found a willow, mangled on one end to expose wood fiber bristles.
“Your old toothbrush?” noted her godmother, “Also nylon.”
“Where’s the water?” asked Greta.
“Down the road in the canal,” replied her godmother, ‘Just make sure you avoid water with cholera in it.”
“Why’s there no running water?” Greta asked, becoming a little peevish.
“Well,” said her godmother, who happened to teach engineering at MIT, “Where do we begin?” There followed a long monologue about how sink valves need elastomer seats and how copper pipes contain copper, which has to be mined and how it’s impossible to make all-electric earth-moving equipment with no gear lubrication or tires and how ore has to be smelted to a make metal, and that’s tough to do with only electricity as a source of heat, and even if you use only electricity, the wires need insulation, which is petroleum-based, and though most of Sweden’s energy is produced in an environmentally friendly way because of hydro and nuclear, if you do a mass and energy balance around the whole system, you still need lots of petroleum products like lubricants and nylon and rubber for tires and asphalt for filling potholes and wax and iPhone plastic and elastic to hold your underwear up while operating a copper smelting furnace and . . .
“What’s for breakfast?” interjected Greta, whose head was hurting.
"Fresh, range-fed chicken eggs,” replied her godmother. “Raw.”
“How so, raw?” inquired Greta.
“Well, . . .” And once again, Greta was told about the need for petroleum products like transformer oil and scores of petroleum products essential for producing metals for frying pans and in the end was educated about how you can’t have a petroleum-free world and then cook eggs. Unless you rip your front fence up and start a fire and carefully cook your egg in an orange peel like you do in Boy Scouts. Not that you can find oranges in Sweden anymore.
“But I want poached eggs like my Aunt Tilde makes,” lamented Greta.“Tilde died this morning,” the godmother explained. “Bacterial pneumonia.”
“What?!” interjected Greta. “No one dies of bacterial pneumonia! We have penicillin.”
“Not anymore,” explained godmother “The production of penicillin requires chemical extraction using isobutyl acetate, which, if you know your organic chemistry, is petroleum-based. Lots of people are dying, which is problematic because there’s not any easy way of disposing of the bodies since backhoes need hydraulic oil and crematoria can’t really burn many bodies using as fuel Swedish fences and furniture, which are rapidly disappearing - being used on the black market for roasting eggs and staying warm.”
This represents only a fraction of Greta’s day, a day without microphones to exclaim into and a day without much food, and a day without carbon-fiber boats to sail in, but a day that will save the planet.
Tune in tomorrow when Greta needs a root canal and learns how Novocain is synthesized.
Sep 8, 2014
266
95
Crested Butte
OMG
I never looked at it that way.
The pursuit of renewable energy will make petroleum products unobtainable!
Hawkster
8,264
6,478
AK
Should be having another dump later this week . That Rhino needs to go , thanks for that above posting , it will be shared . image.jpg
Hawkster
8,264
6,478
AK
No need to bother , it's been removed , BUT......
90 Percent
Of The World's Glaciers Are GROWING - https://principia-scientific.org/climate-shock-90-percent-wo...Apr 17, 2019
This is a really good read but you have to back into it , not directly otherwise this is what you get .
Go to this page
Scroll down to Key People and look up Pierre R. Latour , that is how difficult it is to find information . Once your down to his name you can click on this than it becomes transferable . This is what they don't want you to see , the truth because their agenda would go to **** .
Past Vice Chairman (North) [12]
Hawkster
8,264
6,478
AK
Found whats causing global warming , rail theft CA. yep thier going green .
Hawkster
8,264
6,478
AK
Why is it that climate change is all about going green ? It's so vague , is this what they really mean ?
Hawkster
8,264
6,478
AK
Did not Prince Charles say these exact words and at one of thier G7 meetings ? Guess they have to stay to the script .
